TPI Kicking My Fanny
#42
Installed a new HEI module... no difference. Ordered a reman ECM. Always a possibility that the prom is messed up. PO was in there with a pick & shovel. So where/how do I get a factory replacement prom?
#45
Did you do any troubleshooting? ECMs go bad more often than PROMs, but anything is possible. Could be a wiring issue, too.
#46
RE: troubleshooting... I purchased TunerPro 5 and the Moates cables hoping to get the systems "pulse". I downloaded the appropriate files, renamed them (they download with the htm extension) and imported/loaded them into TunerPro following the authors direct guidance (via email). Tried to "acquire" data. Nothing. Gave up on that. $29 OBD1 scanner doesn't work either.
Wiring Issue: Yup. Could be. Clueless where to start. Everything looks good. Was hoping TunerPro would help me with that. At least ballpark it somehow. This has been educational to say the least. The Honeymoon is over. LOL
#47
The running fuel pressure was 43psi.
I just did a follow up check on the "running" fuel pressure... and it is now 35psi.
Key on/engine off, fuel pressure shoots right up to 43psi. But when I start it, the pressure drops to 35.
Here' is what I think happened-
I jacked the front of the car up as high as I could get it to work on it. There was probably some sludge in the tank, and it probably moved around and plugged up the "sock" or filter on the pump in the tank.
So... when the key is turned on, there is enough fuel in the line to pump up to 43, but once the engine starts to run, the pump can't maintain the required volume to render 43psi. Is that feasible?
35psi cause it to flat spot at 1700-1900rpm?
#48
I was reading something in the tpi forum that sometimes people will try to adjust the idle with the screw. That cant be done properly , Can you try to do a minimum idle adjust it seems to help mine whenever I do it. Make sure timing is on and that your balancer isn't twisting
http://www.digitalcorvettes.com/foru...ad.php?t=58873
#49
#50
Didn't read the whole thread, but have you checked air in/air out?
No chance the air cleaner is blocked?
No chance the cats melted down and blocked the exhaust system?
#51
The factory idle plug is still intact. The car ran when I brought it home. I did something to it, I just don't know what. It idles okay. When it hits 1700-1900 rpm it misfires and does the shake rattle & roll. It can't be forced above 1900rpm.... simply won't rev any higher.
#52
Cats could very well be a problem.
Replacing the fuel pump today. See how that goes.
#53
When I brought the car home, it ran okay. Just a little "sloppy".
#54
Disconnected both exhaust manifolds and stuck a large bolt across the openings between the manifolds and the y-pipe. Exhaust wide open. Still won't rev. Air filter is clean.
#56
Okay... now I'm SOL for a while. I received the "NEW" ECM from AMAZON/Stockwise Auto and the box was opened and full of greasy fingerprints. Obviously, somebody bought it, used it to test, and sent it back. That's unacceptable so it will take me a while to sort this out... Stockwise refused to pay the return shipping for a used part that was supposed to be new.
