Abs help
Old Apr 14, 2017 | 07:22 PM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
Default Abs help
Any one in the 17921 area that has a teck 1 scanner or any scanner that can help trouble shoot my ABS, the abs is not showing any codes via pins A & H, I have the abs is causing the brakes to grab. there was no abs light indicating anything wrong and no codes stored in memory. brakes are fine with the abs power disconnected but I dont like driving around with the light on and I prefer that the abs works. I also noticed that I have not been hearing the abs pump run during self test.
