A.I.R Pump Elimination
Old Apr 17, 2017 | 12:37 PM
mike9380's Avatar
mike9380
Default A.I.R Pump Elimination
1986 C4 smog pump seized and fell off while driving. Can I get the delete kit installed so the serpentine belt runs without removing any lines or plugging the manifolds (basically just remove the smog pump next to the alternator)?
Old Apr 17, 2017 | 02:57 PM
aklim's Avatar
aklim
https://www.tpis.com/parts/view/62
Pull off all the plumbing, cap off the 1 way valves with pipe cap from Home Depot, put a plug at the cat where the AIR pipe goes to it so road debris doesn't get in.
Old Apr 17, 2017 | 03:16 PM
mike9380's Avatar
mike9380
thanks.
Old Apr 17, 2017 | 03:18 PM
aklim's Avatar
aklim
thanks.
Anytime. Take the valves off so you can get the pipe cap at HD or whatever store you prefer. Don't tell the smog ***** or we'll both be shot at dawn.
Old Apr 17, 2017 | 03:40 PM
ddahlgren's Avatar
ddahlgren
Depends on state in CT it is smog exempt.
Old Apr 17, 2017 | 03:43 PM
aklim's Avatar
aklim
Perhaps but there is going to be someone that carps about "You are causing me cancer" when you talk of eliminating emissions stuff.
Old Apr 17, 2017 | 08:09 PM
cdm747's Avatar
cdm747
St. Jude Donor '17-'18-'19-'20-'21-'22
Just did mine. Pipe cap is a standard 1/2" threaded pipe cap.
To A.I.R Pump Elimination
