92 new battery will not start
Old Apr 22, 2017 | 05:54 PM
jhum3662's Avatar
jhum3662
Cruising
Default 92 new battery will not start
i have been dealing with a slight battery drain for a while now. After researching and testing my battery was bad and i replaced with bigger stronger battery. Now It will start with a jump but the moment I remove the cables it dies. It will jump right off, but dies immediately after removing cables. Need some help!~
Old Apr 22, 2017 | 06:44 PM
jhum3662's Avatar
jhum3662
Cruising
Default Need help really bad!!!!!!!!!!!!!!!!!!!!!
Old Apr 22, 2017 | 07:19 PM
RIC96's Avatar
RIC96
New batteries can be bad. Take it in for a test.
Old Apr 22, 2017 | 07:26 PM
A Peter C4's Avatar
A Peter C4
If the new battery is full charged and the terminals are clean and both cables are getting good contact it should not do that, is this a new battery, it sounds like there is not good contact from battery to cables in car that's why it dies when you disconnect the power of the jumpers.
Old Apr 22, 2017 | 10:53 PM
aklim's Avatar
aklim
Define START carefully. Do you mean it will run or just crank?
It sounds like like you have to jump to make it crank. If so, is the starter good? I'd test it and by that I mean take it to a good rebuild place and check it by disassembly. Autozone, NAPA, etc have passed my starter. The rebuild place took it apart and I found burnt oil from the engine valve cover leak long ago.
Old Apr 22, 2017 | 11:13 PM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
If the engine is running until you disconnect your "jumper" battery then you've either got no power in the new battery (unlikely..but they have been known to be bad ) or you've got a open circuit.
Just out of curiosity take a look at the positive cable, if it has the original thick red rubber boot around it cut it off with a razor knife. Mine was loaded with corrosion...all hidden from sight.
later, tiny
Old Apr 23, 2017 | 06:47 AM
bac22's Avatar
bac22
Need to step back first before throwing new batteries at the problem. What makes you think you have drain and how much? If you do have a drain then you need to resolve that issue first.
Drains are not good, that means something is drawing power, and power equals heat and in the wrong location can lead to a fire.
Old Apr 23, 2017 | 08:04 AM
hcbph's Avatar
hcbph
Here's something to think on. You replaced the battery and assume it's fully charged. The car won't start (assume you mean crank and run). Put jumpers on it and it does till you take the jumpers off.
The only area in common you have there is between the bolts on the battery cables and the battery. Here's a quick test you can try (assuming the cable to battery bolts are snug): slip a thin washer (preferably copper) between the cable and the battery terminal one side at a time and try it. If it now works, you're not making a good contact with that cable end and the battery. I've seen a battery that (I suspect) the contact on one post was recessed a little and the cable didn't make a good contact. If that's the case you have three viable options: replace the battery, sand that ridge on the back of the cable so the mounting surface goes further towards the battery or try another cable.
To 92 new battery will not start
