Ignition System Upgrade Advice
Old Sep 27, 2002 | 03:07 PM
CSM87's Avatar
CSM87
Default Ignition System Upgrade Advice
I'd like to upgrade my Stock HEI for more "spark" and efficiency. Any recommendations on a high voltage coil/cap? Plug Wires? Are high performance ignition modules hi-perf or hype? Plugs? Any other tips?
Old Sep 27, 2002 | 05:05 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Re: Ignition System Upgrade Advice (CSM87)
Old Sep 27, 2002 | 06:40 PM
Silver89's Avatar
Silver89
Default Re: Ignition System Upgrade Advice (FlyboyZR1)
and
Old Sep 27, 2002 | 06:41 PM
scorp508's Avatar
scorp508
Stock HEI is great up to about 4500 RPM, your car should be shifted before that anyways. :cheers:
Old Sep 27, 2002 | 10:55 PM
Austin89's Avatar
Austin89
The MSD digital 6+ is pretty sweet.
I'll post pics next week.
Old Sep 28, 2002 | 09:49 PM
dlmeyers's Avatar
dlmeyers
Default Re: Ignition System Upgrade Advice (Austin89)
If your car start and runs good now, then the secondary spark is OK.
For stock applications, spark does not make performance. Fuel and air does that. Assuming you double the spark voltage, it would be like lighting the trash with a blow torch. Thermal energy released would be the same. You called it "hype", sounds good to me. I suspect if you have a stock engine, spend money on parts and dynos, the results would reflect dyno variance.
Now, in heavily modified engines, maybe. Just maybe. Show me the numbers off a dyno.
Spend your money on something else.
dlmeyers 90 coupe zf6 3 speed shocks
Old Sep 28, 2002 | 09:52 PM
Nathan Plemons's Avatar
Nathan Plemons
I'll agree that a lot of the high performance ignition stuff is just hype, but what's it gonna hurt. As part of your tune up you might as well put a good hot coil on there, and especially those MSD wires.
Those are probably some of the best wires out there right now for durability and extreme low resistance. The best spark in the world does no good if it's all disappated as heat by the plug wire. It won't make any horsepower magically appear, but it will make sure that each cylinder fires every time.
Old Oct 1, 2002 | 07:19 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: Ignition System Upgrade Advice (Silver89)
Silver89,
Where did you install the MSD 6, in your vette.....can't figure out where to put it?????
Let me know. OK?
tony :cheers:
Old Oct 1, 2002 | 11:58 AM
Silver89's Avatar
Silver89
Default Re: Ignition System Upgrade Advice (oldace84)
Silver89,Where did you install the MSD 6, in your vette.....can't figure out where to put it?????
Let me know. OK?
tony :cheers:
On the drivers side, in the headlight well. Popular place for it, and an easy fit :)
Old Oct 1, 2002 | 12:22 PM
fullboogie
Let me add that if you plan on taking it to the track, the spark-based rev limiter on an MSD is far safer than the stock fuel-shutoff rev limiter. For that reason alone, an MSD 6AL is worth it.
Old Oct 1, 2002 | 02:05 PM
vader86's Avatar
vader86
Unless your engine has been significantly modded to allow you to go higher than about 4500-5000rpm, you do not need to modify the ignition system.
The HEI is very good until you get to those high rpm.
For now, just a new cap/rotor and MSD plug wires will perform very well. And you can save the money that you would spend on the Digital 6 box for something else.
To Ignition System Upgrade Advice
