my84 corvette cluster
Old May 4, 2017 | 12:43 AM
corvette1859's Avatar
corvette1859
1st Gear
Default my84 corvette cluster
dash went black, gauges stop too, temp and gas. Prior to that my dash would only flash like the hazard lights on & off while driving, only the dash lights would flash, now everything is black, no lights in dash...would like to know whats going on, thanks for your time
Old May 4, 2017 | 02:38 AM
JoBy's Avatar
JoBy
Both turning indicators on and LCD black indicates bad ground. A common problem that is not too difficult to fix.
You will find a lot of information here: http://batee.com/articles.html
Old May 5, 2017 | 06:25 PM
gerardvg's Avatar
gerardvg
Hi
I had the issue where the dash went blank and had high beam and both indicator lights illuminated, was the connector pins between the boards a common problem.
The ground goes through one of those pins over time the connection goes bad.
The batee kit was cheap and fixed the issue.
To my84 corvette cluster
