Removing P/S pulley
I have no hopes of repairing the pulley, but since I have a core-charge on the pump, need to remove it. Is there a better device (3-jaw style?) to use (or did I miss an important step)?
*Also, where do I pick up a new pulley??? When Rockauto doesn't carry something, I get nervous!
Thanks!
Thanks!
I've never done an LT1 car, but i'm guessing the same applies.
BTW, the same tool also installs the pulley. they are usually universal, and remove a variety of manufacturer's pulley types. also, NO impact wrench - hand tools only - on and off slowly
I bought an inexpensive set years ago - think the maker is OTC. probably used it a dozen times w/o issues. they usually cost around $30 or so.
you can buy one at just about any parts store, or autozone, advanced, or o'rileys has a tool loaner problem. as for the pulley itself, good luck finding one in stock for a 20+ year old corvette. it may be something you'll have to order or get on-line - maybe even fleabay.
edit: HOLY SCHITT!!! I don't know if this is the norm, or what, but you may have made a costly mistake. fleabay, used 94-96 pulley, (drumroll) $250 -
http://www.ebay.com/itm/1994-1996-C4...ZYfSdY&vxp=mtr
seems to be a discontinued part (GM PN 10227069). it's probably all about supply and demand -
You also need the tool to properly install the pulley on the new pump. They do not like to go on easily. Went through this with my '76 Camaro last summer.
No idea where you would find a replacement pulley. You may have to research a cross referenced part to the GM part and maybe find one in a wrecking yard.
Good Luck.
https://www.corvetteforum.com/forums..._experts1.html
I believe he might go by "Junior"
