Cruise Control unit on 84.
Old Sep 27, 2002 | 11:09 PM
Boo383's Avatar
Boo383
Default Cruise Control unit on 84.
I finally decided to see why the cruise control doesn't work on my 84. I was looking at the vacuum hoses that connect to it and noticed that one of them was missing. Someone had just stuffed it under the battery!! I simply need to reconnect it, BUT the plastic piece that the hose fits over broke off with the hose and is still stuck in the end of it. Is it possible for me to order just the part where the hoses connect to?? Or does anyone have this part just laying around?? :D TIA!
Old Oct 3, 2002 | 03:23 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: Cruise Control unit on 84. (Boo383)
Boy would I like to find out how to fix it.....not that I use it but.....
Someone disconnected the ball looking thingy....on the driver side....where does it go?????what does it do????
Questions....Questions....Questions....I 'm looking in 1984 Chevy book...($89.00)....and still no help.....if you find out.....let me know...
thanks
tony :confused: :confused: :confused:
Old Oct 3, 2002 | 02:48 PM
Boo383's Avatar
Boo383
Ahhh the mystery!
Old Oct 3, 2002 | 03:23 PM
JonM's Avatar
JonM
Their is a mile of hose for the CC, I don't know which one you are speaking about. Can you point it out?
Old Oct 3, 2002 | 03:31 PM
JonM's Avatar
JonM
Default Re: Cruise Control unit on 84. (oldace84)
Oldace...its an Accumulator ...there is not enough constant/steady vacuum pressure if the CC was just connected to a vacuum on the manifold. RPMs go up and down...as you know... :crazy: That little ball thingy ...as you so eloquently put it... stores vacuum so the CC won't shut off automatically while you are using it. Any variation in pressure will shut the CC off, that is why the break peddle has a switch, every time you hit the break it opens the vacuum and releases pressure and shuts off the CC.
Old Oct 3, 2002 | 07:44 PM
JoBy's Avatar
JoBy
Default Re: Cruise Control unit on 84. (JonM)
Where did you gat that picture? I have never seen the servo in that location.
Old Oct 3, 2002 | 08:34 PM
JonM's Avatar
JonM
Default Re: Cruise Control unit on 84. (JoBy)
Joby...You are correct the servo is mounted on top of the battery. I got that picture out of the main Helms service manuel. I know the servo is located incorrectly but I just wanted to get an idea of what Boo was talking about. The picture still has the same vacuum hoses.
Old Oct 4, 2002 | 01:48 AM
Boo383's Avatar
Boo383
It's the hose that runs to the accumulator ball. I am not looking at it now, but I think there is only one hose that runs from the CC unit to the ball.
To Cruise Control unit on 84.
