Hurst install problem...
Old Sep 27, 2002 | 11:10 PM
graddium's Avatar
graddium
St. Jude Contributor
Default Hurst install problem...
I'm installing my Hurst right now and have run into a problem. I've got the rubber boot pulled back, and the ring moved out from the way of the gear pin, and I'm trying to drive the pin out of the gear shaft/rod. But for the life of me it does not want to budge, and I'm hitting it pretty hard. I am positive the ring wire is out of the way on the top. Any ideas??
Old Sep 28, 2002 | 04:25 AM
STL94LT1's Avatar
STL94LT1
Default Re: Hurst install problem... (graddium)
Make sure the shifter linkage is not in a bind, and just knock the pin out.
Old Sep 28, 2002 | 01:44 PM
Mikez40's Avatar
Mikez40
Sorry can't give any help. but would like to know how your installation is going. How hard was it? Any advice you can give on install.
I just ordered the Hurst shifter, should be here next week.
Any info you can give would be helpful,
thanks,
Mike
Old Sep 28, 2002 | 02:53 PM
STL94LT1's Avatar
STL94LT1
Default Re: Hurst install problem... (Mikez40)
Mikez40, there is someone on this forum that has detailed instructions and pictures on his web page of the Hurst install. Run a search and hopefully you can find it, the web page really helped me with my install. Also, the Hurst install can be very frustrating, so be prepared.
Old Sep 28, 2002 | 03:41 PM
Tony.96LT4's Avatar
Tony.96LT4
Default Re: Hurst install problem... (STL94LT1)
I've done two of these installs and the second install went much quicker because I took down the exhaust(not hard at all). The pin can be tight coming out but will come if the lock ring is out of the way.:smash: The job may be somewhat frustrating but well worth the effort IMHO.
Old Sep 28, 2002 | 03:53 PM
Hib Halverson's Avatar
Hib Halverson
Pro Mechanic
Pro Mechanic
There are two reviews of the Hurst shifter at: https://www.corvetteforum.com/review...490&TopicID=21
The second one includes some installation images.
Also, Chrise Rinehart, the Hurst Engineer who is responsible for the C4 and C5 shifters is available by email for questions at gt1479b@prism.gatech.edu
[Modified by Hib Halverson, 11:56 AM 9/28/2002]
Old Sep 28, 2002 | 04:54 PM
Mikez40's Avatar
Mikez40
Default Re: Hurst install problem... (Hib Halverson)
Thanks guys, as a matter of fact, I bought the shifter from Chrise Rinehart.
That link you gave with the pictures is great.
Old Sep 28, 2002 | 07:50 PM
dizwiz24's Avatar
dizwiz24
Just did mine yesterday (along with a clutch change (which total time took me a week)). My pin popped right out after I moved the ring out of the way. BTW do not remove that ring, or else you will never be able to get the ring back on without bending it back into shape.
Simply push that ring further up the shaft, so all you have to do is slide it back down. good luck
Old Sep 29, 2002 | 12:50 AM
graddium's Avatar
graddium
Default Re: Hurst install problem... (dizwiz24)
Well, finally got it installed. I still could not get the gear pin out, so I decided to take another route. I unbolted the housing from the tranny and took off the lower boot, exposing the flange pin. Knocked that out, and got the shifter out. Assembled the Hurst and put it back in the car and reassembled everything, except the stock exhaust, which I replaced with Corsas. :D
Corsas sound AMAZING, and the shifter is UNBELIEVEABLE. I love them both, well worth the hard work. :cool:
To Hurst install problem...
