Ignition wiring?
Old May 9, 2017 | 12:03 AM
JoeNova's Avatar
JoeNova
Default Ignition wiring?
Does anyone have a diagram or a picture of the column wiring for a C4?
I have an 88 that has no dash harness. It was a save from the salvage yard. Has a carbed 350. It's basically a gutted circle track car. The connectors are all the under the column but I'm not sure where to give power to and where it comes back out for the ignition source and starter. I could wire up a push start button but I would prefer to still be able to use the key and column wiring.
Thanks.
Old May 9, 2017 | 12:42 AM
Joe C's Avatar
Joe C
get a copy of the 88 FSM (two volume set). book 2 being electrical. should have the information you need.
