The difference between A.C. and Heat
Old Sep 28, 2002 | 11:47 AM
C4ForGeeGee's Avatar
C4ForGeeGee
Default The difference between A.C. and Heat
I have a 1994 LT1 Corvette 6 speed :yesnod: Whats the difference between the Air Conditioning and the Heat? Is it just the temperature button being set higher for hot and lower for cold?
Old Sep 28, 2002 | 12:03 PM
Ericthewolf's Avatar
Ericthewolf
Default Re: The difference between A.C. and Heat (C4ForGeeGee)
Yep there is no AC button it changes automatically when you change the temp and it is different from the outside temperature. :D
Old Sep 28, 2002 | 12:51 PM
C4ForGeeGee
Default Re: The difference between A.C. and Heat (Ericthewolf)
Is there a fan continuosly running for cooling and heating all year around?
To The difference between A.C. and Heat
