Daisy Fresh Rookie Please Help
Then you need to spend some time going through it, specifically how to diagnose a problem...It really will help you in the long run, and there isnt anything in that book you cannot do yourself
D.
Since we have EGR, it gets gunked up occasionally.
And since you have an 85, you have a one year only computer and a MAF control.
Most later cars have a mas air burnoff relay. you have a little box that controls the MAF sensor.
If it goes, you need another one.
Gotta believe that they are really expensive by now.
Also, you have a one year only alternator.
Those are $500 rebuilt. take care of it.
https://www.corvettemods.com/C4-Corvette-1984-1996-Alternators-and-Generators_p_7129.html
here is what u need to do: google the minimum idle set procedure. if you havnt done it, do it.
set you min idle to 550 using the screw, with the iac closed (you will know what this means when u read the min idle procedure).
there was an update for 85 to increase base idle to 500 and mant of is go to 550 during this procedure.
i know the 85 very well. great vettes. do that min idle procedure.
you might want to stop replacing parts until we dial in what the problem. cheers. VT.
https://www.corvettemods.com/C4-Corv...rs_p_7129.html
1984 - production - p/n 1105513 (97 amp)
1985 - production - p/n 1105585 (120 amp), 1105450 (108 amp), 10479868 (120 amp)
1986 - production - p/n 1105678 (105 amp)
1987 - production - p/n 1101127 (105 amp)
1988 - production - p/n 1101264 (105 amp)
1989 - production - p/n 1101264 (105 amp), 1101238 (120 amp)
1990 - production - p/n 1101264 (105 amp), 1101238 (120 amp), 1101849 (120 amp), 1101843 (105 amp)
1991 - production - 1101601 (105 amp), 1101597 (124 amp)
coupeguy2001 -
appears 84 and 85 are the same and also there are choices on the amps. here is another link from mid america.
http://www.mamotorworks.com/Corvette/subcategory/c4-alternators
http://www.mamotorworks.com/Corvette...c4-alternators
