switching a cam
Old May 14, 2017 | 06:29 PM
Youngty25's Avatar
Youngty25
1st Gear
Default switching a cam
I have a stock 350 small block, and wanted to get a Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 278/288, Lift .420/.442 wanted to know if i can switch this and use the same cam bearings. it has 5,000 miles on it
Old May 14, 2017 | 08:20 PM
Need A Vette's Avatar
Need A Vette
The answer is yes...cam bearings are fine. But if you change a cam you MUST also change the lifters.
D.
