Changing coolant
Old May 14, 2017 | 06:50 PM
onDjuice's Avatar
onDjuice
Default Changing coolant
My 92 needs the coolant replaced. Has anyone used the newer dexcool in the older cars... Thanks
Old May 14, 2017 | 08:38 PM
A Peter C4's Avatar
A Peter C4
You should do a complete coolant flush that involves removing the knock sensors and flushing the block. No need to use dexcool, reg old school green glycol is what belongs in the system, don't chance mixing the 2 types if you don't get all the original out, like some still in heater core, that's a no-no. Why would you change from what's recommended? Also if you use straight anti freeze, not premix, best to mix with distilled water, not tap water for a 50/50 mix.
Old May 15, 2017 | 02:41 PM
Kettsvette's Avatar
Kettsvette
My '88 Owners Manual calls for using Ethylene glycol which is the conventional green coolant rather than the GM DexCool coolant. I took my car to the local Chevy dealer who topped off my coolant with the DexCool stuff and it turned my cooling system into a grey oily solution that was most difficult to flush out. I am now back to the conventional ethylene glycol coolant and the car's oil temperature seems to be more consistent than previously noticed. So, I suggest you use whatever is in the owners manual.
Old May 15, 2017 | 04:56 PM
c4cruiser's Avatar
c4cruiser
No real reason to "upgrade" to DexCool. DexCool does allow for not needing to do a coolant flush for 5 years but the regular ethylene glycol coolant is usually changed every two years but it works well and will cost less.
The biggest difficulty in going with DexCool is having to make sure you completely flush all traces of the green coolant. The two coolants don't play well together when mixed. You could get a nasty brown liquid that can cause blockages in the system.
As mentioned, use distilled water when mixing the green coolant. You can find distilled water at any grocery store for something like a buck per gallon. And buy the concentrate version of the green coolant. It's available in a 50/50 mix, but it's more expensive than the concentrate.
The flush/refill procedure in the FSM calls for draining the old coolant and fill with water. Start the engine and let it get to operating temp. Then drain and refill two more times. At that point you can refill with new coolant. It's a good idea to remove the knock sensors from the block which will insure that all of the old coolant is drained. It's also a good time to replace the upper and lower radiator hoses at the same time.
And don't let any coolant drain down over the OptiSpark. Bad (expensive ) things will happen.
Old May 15, 2017 | 09:50 PM
onDjuice's Avatar
onDjuice
I drained my rad.. Its brown sh@t looks like i have to flush the system a coupe of times to get all the crap out.. Thanks guys
Old May 15, 2017 | 10:03 PM
A Peter C4's Avatar
A Peter C4
Be sure to remove knocks to get a complete flush, each time when you refill with just water and run engine 2 or three times, then new knocks, torque to 14 ft. lbs.
To Changing coolant
