1994 Front Shock Install
Old May 15, 2017 | 01:51 PM
94Green's Avatar
94Green
C6 of Year Finalist (stock) 2019
Default 1994 Front Shock Install
I recently bought a 94 Corvette Base Model. The front shocks were worn out so I bought the cheapest shocks because all I do is go for occasional cruise. The front shocks look different than the original Bilstein's .
I bought the OESpectrum brand at O'Reiley's and I can't figure how they go back on at the top, the bushing's are different looking.
Any help would be greatly appreciated.
Mike
Old May 15, 2017 | 02:02 PM
Need A Vette's Avatar
Need A Vette
How can they be different? though they aren't bilstein, they should still have the upper mounting shaft. Care to share a pic of what they look like?
D.
Old May 15, 2017 | 02:09 PM
hcbph's Avatar
hcbph
D.
Trying to put a rear shock on the front?
Please post pictures of your issue.
Old May 15, 2017 | 03:09 PM
94Green's Avatar
94Green
Default Rubber Bushing in Center - It is from the original shock, does it come out too?
R
Mike
Is the rubber bushing in the center supposed to be there, it is from the original shock set up. It didn't seem like it wanted to come out so I left it in there for now.
Old May 15, 2017 | 03:20 PM
Aerovette's Avatar
Aerovette
The stack up is usually
Shock then washer then rubber bushing>frame<rubber bushing then washer, then nut or nuts.
Old May 15, 2017 | 03:21 PM
Need A Vette
From bottom to top you should have the following, in this order:
Metal Curved Washer
Rubber Bushing
Mounting Plate on car
Rubber Bushing
Metal Curved Washer
Just think of it as a sandwich where the washers are the bread, the rubber bushings are the meat, and the mounting plate on the car as the lettuce between the Ham / Turkey...lol
D
Old May 15, 2017 | 03:24 PM
94Green's Avatar
94Green
Thank you. If you look at the 1st and 2nd picture, there is a bushing that is attached to the frame where the shock mount bolt goes through. Should that one be removed as well or does it stay as part of the front end frame assembly mount?
Old May 15, 2017 | 03:37 PM
94Green's Avatar
94Green
Does this original bushing stay in? It was not part of the replacement shocks hardware.
Old May 15, 2017 | 03:38 PM
Need A Vette
Pull it...it needn't be there
Old May 15, 2017 | 03:39 PM
Aerovette's Avatar
Aerovette
It's been a while since my C4, but as far as I know, all you need is what came with the new shocks. One of the rubber bushings should have a step in it that will fit into the hole. This isolates the shock shaft from the frame when the two bushings are squeezed together.
Old May 15, 2017 | 03:41 PM
94Green's Avatar
94Green
Default Does this original bushing stay in? It was left from the original shock
Metal Curved Washer
Rubber Bushing
Rubber Bushing
Metal Curved Washer
D
Old May 15, 2017 | 03:45 PM
94Green's Avatar
94Green
Thank you so much!! Just a screwdriver to coax it out? Doesn't matter if it gets torn then?
Old May 15, 2017 | 03:55 PM
81c3's Avatar
81c3
No, throw it away... Make sure when tightening you jus start t see the bushings bulge a bit....
Old May 15, 2017 | 03:59 PM
Aerovette's Avatar
Aerovette
I actually think they are supposed to bulge to a matching diameter. No?
Old May 15, 2017 | 04:03 PM
81c3's Avatar
81c3
Should be they bulge a tad past the diameter of the large washer.
Old May 15, 2017 | 04:19 PM
hcbph's Avatar
hcbph
Check the instructions that came with the new shocks. Most I remember doing had the installer tighten the top nut till the bushing compressed and expanded out to the diameter of the washer both above and below the shock chassis mount.
I assume yours is like mine: don't overtighten the nut initially. Snug it initially loosely then push-pull the shock a little. There should be a small shoulder on one side of each of the bushings with it towards the chassis hole side, you want them centered in the chassis hole they go through. Once centered, then tighten up the top nut to the prescribed tightness.
Old May 15, 2017 | 04:25 PM
94Green's Avatar
94Green
I think so, they always look that way anyhow.
Old May 15, 2017 | 04:29 PM
94Green's Avatar
94Green
There was no directions in the box the shocks came in. Arggh, thus this thread.
Old May 15, 2017 | 06:56 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Metal Curved Washer
Rubber Bushing
Rubber Bushing
Metal Curved Washer
D
This ^.
Concave side of "metal curved washer" goes against the rubber bushings. Rubber bushing have small shoulder that goes inside the hole in the frame. Tighten nut until rubber bushings expand to same diameter as metal curved washers.
To 1994 Front Shock Install
