What cam should i get?
I am putting in a engine into my 1990 Corvette as the motor is currently seized. The Engine I will be using is a freshly rebuilt l98 350 5.7 tpi engine from a fbody with the stock iron heads. I will be using Edelbrock 60859 heads and either 1.5 or 1.6 Roller rockers, for the Intake manifold I will be using TPIS 1204 Miniram along with 26lb injectors and 58mm Throttle body. The 1990 Corvette Is an automatic with 3:73 gears and a shift kit with a stock converter. I have a 2400 B&M converter which i will be using depending on your recommendation of cam. So My question is I am not sure which Cam i should be using. This car is not my daily driver and there is no emmisions where I live.
Questions;
What Cam would you guys recommend? Has to be tunable for speed density and sized right for the edlebrock 60859
I had in mind Compcams 280XFI
Parts that I have in my possesion;
1. L98 engine
2. TPIS 1204 Miniram/Accel 26lb injectors/58mm TB
3. Edelbrock 60859 heads
4. 2 sets of 1.5 Roller rockers (Scoropion and crane cam) and 1 set of 1.6 Roller rockers (cranes cam Gold)
5. 2400rpm b&M torque converter
6. Stock headers with stright dual exhaust no cats
Need;
1. Pushrods
2. Camshaft
3. Tune
But I have used Ed Wright/Fastchip.com in the past.
Stock manifolds will be a restriction. I didn't notice that you were using a 350, but 280 will be a bit big for that and I might go a little smaller, between 220-225 intake and 220-230 exhaust @050".
