Code 34 / MAF voltage
Old Sep 28, 2002 | 07:57 PM
gsvette's Avatar
gsvette
Hoon
Default Code 34 / MAF voltage
I keep getting a code 34 (gm/sec low) on my 88. Replaced the MAF and both relays, but still get the code 34.
I am not sure if this is correct, but I read that at idle, you should read about 2.5V on the green wire coming from the maf, and that it should increase linearly with throttle.
I am reading right at .7v at idle and the voltage swings smoothly with varying throttle/rpm.
Any ideas???
:chevy
Old Sep 28, 2002 | 08:29 PM
detto's Avatar
detto
Default Re: Code 34 / MAF voltage (gsvette)
On the 86 it should be 0.5 at idle and 4.7 at full throtle
not shure on witch lead you should measure that!!
the green one?? think there is five of them "a b c d e" :rolleyes:
Old Sep 28, 2002 | 08:55 PM
gsvette's Avatar
gsvette
Hoon
Default Re: Code 34 / MAF voltage (detto)
.5 volts sounds correct to me, so mine at .7 is probably OK too. Sounds a lot like the MAF voltage should match the TPS voltage at idle.....
Old Sep 28, 2002 | 09:28 PM
detto's Avatar
detto
Haynes manual says..... Check for air / vacum leaks clean TB check MAF sensor.........and so on!!
Does it runs ruff??
I would try to reset the ECM and start the car and check if the problem is
still present or intermittent :)
To Code 34 / MAF voltage
