I don't really know but brake hoses and park cables are different part#s. Newer lists caliper bracket, older no bracket listed. But it may be possible .
If I had the newer calipers with built in parking brake actuators, I would switch to the early with drum parking brake. I think that the early type is better with less problems.
You probalby have to change the knuckle and wheel offset will be changed.
