Clutch Noise?
Old Sep 28, 2002 | 10:24 PM
robblk90's Avatar
robblk90
Default Clutch Noise?
When the car is in neutral and just sitting you can hear a rattle. As soon as I push in the clutch pedal it stops. It is not that bad but you can hear it when it is next to a wall or another car. I got the car with 32k on it and I believe that everything is stock. What could this be? Throwout bearing? Is there an "easy" way to fix this? I have to sell the car and I am worried about a prospective buyer being scared off by this. It almost sounds like it's coming from the oil pan. Thanks in advance.
Old Sep 29, 2002 | 11:29 AM
Gareth's Avatar
Gareth
Default Re: Clutch Noise? (robblk90)
I have a similar problem on my 88. Sounds a bit like a cricket singing, then as soon as you dip the clutch pedal a fraction it stops. My mechanic friend said that it was the thrust bearing and squirted some lubricant through the rubber boot. This stopped it for a while but it came back aferr a week or so. I intend to drop my 4+3 out this winter and I will do a bit more investigation then. I hope one of the more machanically minded posters can sort us out!
1988 Z51 4+3 manual, Adjustable Fuel Pressure regulator, K & N Filter with cut lid and removed MAF Gauze, Ported cylinder heads (gasket matched), Ported stock headers (gasket matched), Comp Cams Grind: 264 Lift: .487''/.495'' ,Comp Cams Magnum 1.6 ratio, 3/8'' Self Aligning Roller rockers, Comp Cams Up-rated valve springs, Comp Cams 5/16'' (Heat Treated) Push rods, Crane Roller timing chain, Ed Wright ‘Fastchip’
Custom Post CAT exhaust – no boxes
Old Sep 29, 2002 | 10:27 PM
robblk90's Avatar
robblk90
Default Re: Clutch Noise? (Gareth)
Anyone else?
Old Sep 29, 2002 | 11:06 PM
Putter's Avatar
Putter
If the dual mass flywheel has been replaced with a single mass flywheel, pp, & clutch setup, you are experiencing the gear rattle that comes with a smf. If it is the original equipment dmf, the torsional springs in the flywheel may be losing their tension causing the flywheel to clatter. My 90 has 32,000 miles on it. It sounds like I have a rod knocking, yet it is the dmf. When I put the clutch in, it quietens down, but does not disappear until I let the clutch out in gear. You may want to go to http://www.billb@zfdoc.com for the whole explanation.
To Clutch Noise?
