pulling engine codes on 94
Old Sep 28, 2002 | 11:04 PM
Utahvette's Avatar
Utahvette
Default pulling engine codes on 94
hey guys what pins do you jump on 94 to get service engine codes?
thanks in advance.
Old Sep 28, 2002 | 11:11 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: pulling engine codes on 94 (Utahvette)
If in 94 the ALDL connector is still square, you are looking for pins A&B which happen to be in the upper right hand corner. Jump these and turn the key to the on position and your SES light will flash the codes.
Old Sep 28, 2002 | 11:15 PM
Nathan Plemons
Ok, I just looked in my service manual. It says that in 94 you could have either the 12 pin or 16 pin connector. If you still have the 12 pin connector you can do what I said above, if you have the 16 pin they claim you'll have to use a scan tool.
Old Sep 28, 2002 | 11:16 PM
Utahvette's Avatar
Utahvette
Default Re: pulling engine codes on 94 (Nathan Plemons)
its actually tapered on one side and numbered from 1 to 16
thanks for help though.
Old Sep 29, 2002 | 11:25 AM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Same answer as other thread:
From David-F
You can't jump A to B on a 94 it uses a 16 pin ALDL connector you have to jump 4 to
12 which is the 4th from the left on the top row and the one just under it. Then turn
the key on and watch the speedo were the speed is displayed and you will be able to
read code in 1.1 CCM, 4.1 PCM(ECM), 9.1 ABS/ASR, A1 SIR.. Then let us know what
you find and let us know and we can go from there.
David Fulcher
Old Sep 29, 2002 | 12:07 PM
Utahvette's Avatar
Utahvette
Default Re: pulling engine codes on 94 (PeteL)
ok heres what I got: 1. C12 4. h15 nothing on 9. and nothing on A and then it stopped at 1.0
thanks
To pulling engine codes on 94
