96 modified auto shift pressures
Old May 21, 2017 | 04:51 PM
Bigpoop's Avatar
Bigpoop
Default 96 modified auto shift pressures
Just some screen snaps of LT1-Edit modifications to auto shift table. INCREDIBLE difference. Will hit 2nd chirp and shifts excellent. 2/3 is GREATLY improved. LONGEVITY IS UNKNOWN..USE AT YOUR OWN RISK. But it is a simple straight forward change. No modifications to shift timing or learning tables. Mainly just a rise in pressure and a dribble down to underlying tables.
I did mode modify some of the speeds at which it shifts....usually up 2-5 mph. But that is a personal preference of test and tune. This is by no means a 'safe' modification. Not enough data on web to confirm. I also turned off abuse mode.
I'll take the risk, you will have to assess on your own, but the POINT is this WORKS.
Good luck, and I threw in a 160 thermo fan on/off for good measure.
I certainly appreciate EVERYONE's comments...ESPECIALLY GUYS THAT HAVE BEEN THERE DONE THAT....NOT INTERNET GURUS.
NOTE: 55,000 miles 'virgin' tranny. No shift kit or converter. All stock.
Old May 26, 2017 | 06:07 AM
sprink94's Avatar
sprink94
Excuse my ignorance...but how did you access the ECM to see this screen?
