Aftermarket exhaust
I've heard the best is a corsa exhaust although I've never seen one myself, supposed to sound good with good gas flow... I'm looking at changing my stock exhaust as well...
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Have you decided what you want in an "exhaust system"? Do you mean just main mufflers, or everything from the heads to the tips? Cat-back?
Manifold-back?
Check out all the Corvette vendor's catalogs. You'll find something that will appeal to you and your wallet.
Just keep in mind: As in all things, you get what you pay for.
Manifold-back?
When I had L98 car, I tried a few different systems and they all droned and resonated the interior.
I ended up putting a stock LT1 exhaust on it and loved it. This was a 500hp supercharged car.
-- Joe
For what purpose? Better flow to make more power? Probably should do LT headers. Does it need to last? If so, when do you drive it? I drive sometimes in the winter when there is now snow so I prefer a SS exhaust. How long are you keeping the car? If not long, why bother? Do you need the rice effect or is it power you are looking for? How much power to be happy? How much to spend?
Manifold-back?
Manifold-back?
Fair enough. Unfortunately, for a grand, I honestly think you will be better off with a good set of LT headers, power wise than mufflers. I think your choke point is further up than the mufflers. Sound, hard to say what you like or don't. For me, I want quiet so the Borla I got sometimes pisses me off.
Hjhvette (05-22-2017)
If he's looking for a tone change, swap out the mufflers.
I don't think he's going to get much of a performance increase in anything he does exhaust wise. It's a tired, low performance L98.
-- Joe
Received 1,401 Likes
86 could have iron 624 heads or 128 heads.
If you only want sound, go ahead with the catback. Keep in mind that you will probably spend a little more than 1K for any of them worth having. You would be best off by replacing the main cat as well with a Catco or RandomTech, which will cost another $250 or so, as with age yours has likely clogged up. Doing that will probably free up about 10hp as all of the L98s exhaust is pretty restrictive.
Headers would be a fine choice but I see no reason to do them first for what you say you want out of it. Do the catback and see if you are happy with it. If you want more sound than that go with TPiS headers, but with headers + catback, be prepared for resonance.
Most catbacks only vary in sound, not power gains, so pick based on what growl you want. B&B/Borla are fairly loud and will resonate, a Corsa set would only be loud when you stand on it, others fall in between.
Pro Mechanic
Low hanging fruit. I think the LT1 take-off exhaust is a great suggestion. Cheap, and should net some gains.
I will go a different route next time. BB for example, provides its C4 exhaust in several pieces, and now I understand why. A lot of adjustability. Also their mufflers/tips fit my eye and sound nice without being obnoxious. My preference.
Just my own experience/opinion, for what its worth.
