Power Steering Fluid Puddle After Jacking Up
So here's where it gets weird, the whole frame support where the rack sits is dripping so can't pin point the location of the leak where the pool of fluid recently occurred. I guess I'm just looking for reassurance that it's with a failed seal on the rack that it would leak if jacked up like it did. The last thing I want to go is grab a Z51 rack and put it in if its a hose or something else that I'm just not seeing. The car was not started prior to noticing the leak if that helps.
If I do indeed do the rack, how hard of a job is it to do yourself? I had 2 local shops quote the labor at about 500 + alignment. Is it possible to get it out, without having to get under the car? Like put it up, wheels off, and loosen all the fittings/bolts top side and through the wheel well, and pull it through the wheel well? I can source a part for mid 2's or get the original rebuilt if I do the work myself. Its going to be hard to drop 800 in parts and labor if I go the shop route. The wife is already complaining its a money pit.
but one could have been added.
If the rack was leaking it would come out of the ends, where the tierod ends are.
Could be a line, etc.
De-grease your engine, top off the fluid watch to see where it's coming from...
If you do have a cooler, it's possible it was crushed by the jack?
and i had turnone rebuild my rack, they did a fantastic job, however my rack had to be sleeved...
My buddy at work thinks the seal was busted and when I jacked up the left rear it came out the boot. I've felt the boot and can't feel any noticeable fluid. Odd thing is that I've been keeping an eye on the fluid since eive got it. My dad had to fill the reservoir prior to putting it on the car transportor which shocked him. The fluid did not drop dramatically (it did slowly drop though) for the past month I've had it here in Florida. It wasn't till she got jacked up, from the rear of the driver side, that I had a pool form and the reservoir down to the min mark. It's odd that it was on the support where the rack sits though which has me wondering.
From the sounds of the situation, the rack has an internal leak and it is going to have to be rebuilt. If you remove your rack and send it into us, we can take a look at it for you. Visit our website at https://www.turnone-steering.com/pag...lding-services for more information or give us a call at 1-877-GO-TURN1.
Please let me know if you have any questions!
Thank you,
Jeff
President of Turn One
The rack isn't terrible to do yourself if you understand the basic concept of replacing a steering rack and making sure its centered before installation and know a few trick to remove the steering shaft from the rack.
I will give it a good once over and make sure the fittings and hoses are as close to spotless as I can get them, fire it up and turn the wheels a bit with some clean cardboard under it. I'll try to pinpoint and verify the leak better. I won't be able to do this till closer to the weekend for personal reasons so the red sled will have to wait.
Pretty much it feels like the power steering pump is not working 100% and it's hard to turn until everything warms up.
My car started off small, mild morning sickness, later i noticed my ps fluid was grey (aluminum), then it got worse, super hard to turn when cold, flushing the fluid would help a little for a short while...
Issue as i understand it, no power steering cooler.
if you end up like that, turnone is the place to send the rack.
I also had a 2.0 ratio Z51 rack that i wanted to keep, at the time there were no rebuilt 2.0 racks available from any parts place...
My rack has now been sleved with stainess steel if i understood them correctly, and it's flawless.
Hardest part was getting a box to ship it in, i ended up making my own box out of a mattress box and lots of tape...
That's one service i wish they offered, having a box shipped to me.
(hint hint)
This morning I took it out for a good hour before work and got everything up to temp and zig zagged through my neighborhood making sure to put the rack through its paces. I'll check when I get home and verify any drips.
I have used steering fluid with seal conditioner/stop leak when I topped off the fluid after it came off the the car carrier and after the puddle occurred so I've burned that option already to delay things. The car also needs an alignment as it tracks to the right, even on level road/parking lot.
I also intend to complete the full brake job I intended on doing last weekend, which is when the monster leak occurred. Its the fronts so I'll be up close to the boots when the car is lifted and lowered as thats when this appeared leak the worst.
So from the looks of it.. Its the rack.
