trouble codes and 94 vette
Old Sep 29, 2002 | 02:02 AM
Utahvette's Avatar
Utahvette
Default trouble codes and 94 vette
hey guys, Im alittle confused about OBD I and OBD II. I have a 94 with a 16 pin connector Ive read that that is an OBD II connector but the car is just OBD I compatible so my question is what all do I need to read my trouble codes, all I can find are OBD II code readers.
thanks for any help that you can pass my way.
Old Sep 29, 2002 | 03:24 AM
Deadcarny's Avatar
Deadcarny
Default Re: trouble codes and 94 vette (Utahvette)
you are going to need a code reader for an OBD I, but you will need one that has an OBD II cable.your best bet may be find someone near you with a cable and a scanner that can check your codes for you. i would hook you up, but i am kinda far away!
