'96 LT4 possible clutch issues...am I screwed?
I have a '96 LT4 car and I'm wondering if anyone else has dealt with the transmission/clutch/flywheel saga for these later-year C4 cars succesfully in the past couple of years. I've done a lot of reading on here and everything I read about is that changing clutch components with original parts (read: DM flywheels) is basically impossible since there aren't any and switching to a SM flywheel unit ruins the car.
Anyway, I believe my pilot bearing is damaged and making some noise after I completed a track day at Putnam park about a month ago (when I clutch in all the way and I hear a rotating metallic rattling noise). Clutch grabs fine and the car has 95k miles, no idea on previous service from previous owners (I've had that car about 4 years, 11k miles or so). I'm wondering how much of a pain it is to change the pilot bearing and any other related worn clutch components and master/slave cylinder stuff. I'm not very handy and I don't have a lift or many tools, so it's unlikely I'll be able to do any this myself. Money is less the issue than where to go and what parts to source such that I can maintain the stock character of this otherwise amazing car.
Is it a stupid waste of time to just replace the pilot bearing and friction disc and nothing else? What parts should I replace and who sells them? I don't want to convert to single mass flywheel if my DM unit is bad either. Any shops in Ohio (central or NE) that can do this kind of work? Would a Chevy dealer even touch this as a last resort? Should I give ZF Doc a call? Any advice on this issue would be greatly appreciated.
5abivt (05-22-2017)
AGree sounds like the throwout bearing. But yes, if the pressure plate is original it is a higher clamp load than the std LT1 pressure plate. Id recommend a GM disc replacement, new pilot bearing and throwout bearing and youre good to go.
Yep, this is basically what I'm thinking. Can any independent shop be trusted with this? Should I use a Chevy dealer, or Corvette shop? What are your opinions about Corvette specialty shops versus dealers (for quality reasons, I think we all know why dealerships are called stealerships for cost reasons).
Sorry I'm late to this topic. Agree with the others it sounds like a throwout bearing. But once in there it's minimal extra work to replace the pilot bearing and disk. If your pressure looks decent, keep it! "Decent" means it can have heat colorations but not lots of gouges from the disk rivets (happens when disk wears down), and it is still flat. The original Valeo plates are what you want, and they are very hard to source now. If you like the DM flywheel and it looks okay, reuse it too. If not, you will have to use a single-mass wheel, but you can get a steel one that has more mass for a bit less noise. If you have to go that route, make sure the new disk has a sprung hub! The OE one is a solid hub for use only with the DM flywheel.
On the throwout bearing, I strongly recommend finding an new-old-stock INA brand bearing. I had a "performance" clutch brand's throwout bearing lose its seal and ruin a nearly new clutch. You can try calling Jim at Power Torque Solutions: (641)342-7446.
For the pilot bearing, get a fluted oilite bronze solid bushing. Other solid bushings are suspect. Needle bearings are more delicate - mine came out in small pieces! Don't put any oil on the bronze bearing! It is self-lubricating, and may actually fail if you add oil to it.
Any decent shop should be able to do this. The only real tricks I can think of are getting the stock shift **** off the stick, and dealing with the rubber shifter boot under the leather one. You can look up the tricks on the shift **** (mine isn't stock, so I've never done one). After removing the rubber boot on mine, I recommend leaving it in place. This probably requires a helper when the trans comes out and goes back in, to guide the shifter through the hole in the boot. But it's a real pain to put back over the opening in the tunnel if you take it off. I think everything else is standard procedures.
1. Let's say my DM flywheel is hosed and I need to go SM. Which SM unit should I use, and, which spring hub'd friction disk should go with it? I'm really not a transmission guy so I had no idea there was all this variation between flywheel and friction disk combinations.
2. Would power torque solutions have all of this information? I'm wondering which vendor has the best reputation for outfitting later C4's because I feel like I need people who know these parts intimately in order for me to get this right.
3. I have seen other threads on here talk about bronze bearings and how they're really what you should get, so this confirms what I read.
4. What other common trans/clutch items go bad? I hear a lot about master cylinders and slave cylinders, clutch forks and this and that. I'm not entirely sure what these are and I'm sure they're hard to source too. Should I replace more items since I'm in there anyway? Or should I not touch them until I know they're bad? Thoughts on this?
Thanks again.
I have had a Fidanza SM aluminum flywheel in my 93 Lt1 for 20 years (only 35,000 miles however.) There is absolutely no problem and no noise from it unless you shift to neutral and let the clutch out. Then you get the rocks in a can noise. But normal stopping at a light or stop sign with the clutch depressed it is quiet as a DM.
For a stock or near-stock power level, and especially if you want to retain good modulation on the street, go with an organic disk. I had an organic disk in my 396 with probably ~500hp at the crank, and it lasted for many years. I wish I'd put another organic one in. RAM and Centerforce seem to have good quality disks. Again, make sure you stick with full organic and not a dual-friction type of disk. I am no expert on best brands, but this is what I've gleaned from my experiences so far.
If you end up replacing the flywheel, you may want to consider ARP flywheel bolts and the special washers that go with them. Make sure to get their special assembly lube for the bolt heads and use Loctite on the threads. They have very specific directions about all this on their website. You'll probably need to refill your trans fluid after all this. You can check out about a zillion threads on this forum regarding what's best. I'm using a fluid that nobody else uses and I don't think you can get it anymore anyway, so I won't be much help on this topic.
OTOH, if you are going to switch to a single-mass flywheel and therefore want to buy a sprung-hub disk, looking up the disk by your actual vehicle will either not get those search results, or it will get you a mix of sprung and non-sprung disks. The easy way to search for sprung-hub disk is by looking for a replacement disk for a 96 Camaro V8 (Z28). Those cars had a completely different transmission that wasn't noisy and didn't required a DM flywheel, so they came with single-mass flywheels and sprung-hub disks. But they were the same diameter and the input shaft was the same diameter and spline count (26). IOW, the only difference in the disk for a Z28 and Corvette was that the hub was sprung on the Z28 but solid on the Corvette. So that search will get you the correctly sized disk with a sprung hub.
As and FYI Jim at powertorque has retired and sold off his remaining stock. Another wrench to throw in the mix.
I knew he'd shut his website down, but didn't know he officially retired and sold off his stock. That's too bad. Maybe ZFdoc has some OE parts, or a line on some?
This has been extremely helpful! Thanks guys, I knew the forum would come through. I will likely do this repair at the end of the season and until then I won't do any more HPDE's or anything else until this issue is fixed. There is a Corvette shop in Cleveland that has done some frontal engine work on the car before, it is possible that they can handle this is well. If not, a reputable transmission shop. Thanks again for the advice and I'll see if I can come back with a success story!
Charles
Charles
Please do let us know how it turns out!
Dmf clutch disk doesn't use coupling springs
Smf kit has clutch disk with coupling springs
Am i right?
