1995, Replace Oil Temperature Sender ??
Old May 23, 2017 | 10:29 PM
8valve's Avatar
8valve
Default 1995, Replace Oil Temperature Sender ??
I have a 95, LT1, 6 speed. I need to replace the oil temperature sender since the top (connector)
is broken off. How in the world do you get to the sender to get a wrench on it. I cant hardly get my hand and a mirror up there.
8Valve
Old May 24, 2017 | 08:02 AM
don hall's Avatar
don hall
You might make a trip to a dealer, and ask to talk to a tech/service mgr.
for instructions, or ask for a quote.
The location of the oil temp sender (in the base of the oil filter housing)
makes it extremely difficult to replace.
I have read posts that quote $600 to replace oil temp sender.
Old May 24, 2017 | 10:41 AM
vader86's Avatar
vader86
Did mine on the 88 this weekend, not a fun job. I believe the later cars are basically the same piece with a different electrical connector.
3/4" ratcheting wrench, no mirror, just feel for it. Its way easier if you have a lift or can get the car well up in the air to get some leverage and be able to see it.
Old May 24, 2017 | 10:22 PM
8valve's Avatar
8valve
Thanks Guys for the tips. I will try a ratchet wrench. I do have a Kwik Lift so up in the air is no issue. For sure I am not paying a dealer to change it for big bucks.
8Valve
Old May 25, 2017 | 12:05 AM
A Peter C4's Avatar
A Peter C4
I also need to r+r my temp sender, it's leaking, should I remove oil filter adapter first for better access? Also I think my oil pressure sender is leaking and need to r+r.
Old May 25, 2017 | 10:45 AM
vader86's Avatar
vader86
It would be easier to do with the oil filter off.
To 1995, Replace Oil Temperature Sender ??
