Meziere EWP help
Old May 27, 2017 | 12:46 PM
Teothe1nonly's Avatar
Teothe1nonly
Default Meziere EWP help
Hey guys, anyone with a meziere pump tried replacing a meziere pump? I know , tricky question. My meziere unit is leaking and I have a spare tested in working order one on the side, I have 2 questions about the replacement.
question 1, will my ac accumulator get in the way of me trying to replace the unit?
question 2, I bought a new water pump cover o ring to use on the new meziere unit, should I use silicone? Or is the new o ring all that I need?
My mechanic used silicone and the o ring on the first pump that is currently installed and I have a feeling the silicone is what is causing it to leak. Tried searching the forum but to no avail. Any help would be appreciated, oh yea, my car is a 96 CE
Old May 27, 2017 | 02:55 PM
Teothe1nonly
anyone?
Old May 27, 2017 | 10:40 PM
A Peter C4's Avatar
A Peter C4
You could contact Merziere for there recommendation .
Old May 28, 2017 | 05:02 AM
STL94LT1's Avatar
STL94LT1
I installed my Meziere with just the o-ring. No leaks for over 10 years.
Old May 29, 2017 | 08:56 AM
jmgtp's Avatar
jmgtp
At least 5 years on mine, just the o-ring. No leaks.
To Meziere EWP help
