Antenna Problems
Old Sep 29, 2002 | 08:50 PM
RedZR's Avatar
RedZR
Default Antenna Problems
Hello Gang,
I encountered a problem with my 91's antenna last night.
Basically it will not retract, I can push it in by hand and it comes up when you turn the radio on.
However it will not go down after I shut the radio off.
Is that little ribbon thingie broken or am I looking at buying the entire unit because something else is bad?
Thanks,
Da
Old Sep 30, 2002 | 01:11 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: Antenna Problems (RedZR)
More than likely it's the ribbon. I replaced mine as well as my friends, and it was pretty simple. Mine all I had to do was replace the ribon and mast. On his I had to actually remove the antanna unit and unscrew it to remove the rest of the ribbon inside it.
You should be able to go to a local dealership and have the mast kit ordered (I can get the part number for you) it cost around 24 bucks. It includes a tool for removal of the nut that holds the antanna in place. The kit will have instructions as well.
Old Sep 30, 2002 | 09:50 AM
92TripleBlack's Avatar
92TripleBlack
Default Re: Antenna Problems (Jeffvette)
They have the directions on the http://www.madirect.com site. Its easy and quick. I found it easier to remove the entire assembly on my vert. I've heard this is harder to do on coupes requiring the fender well to be partially removed though.
Old Sep 30, 2002 | 02:17 PM
Jeffvette's Avatar
Jeffvette
Default Re: Antenna Problems (92TripleBlack)
On the ZR-1's you can just reach up with tools, screwdriver and a socket wrech to get it unmounted. Love the extra 1.5 inches on each side.
To Antenna Problems
