push button switch
Old Jun 1, 2017 | 06:13 PM
hughesm's Avatar
hughesm
Default push button switch
hi guys does any body know what type of push switch you need for a 1988 4+3 . my quit working and I can't get it out of overdrive..thanks any help appreciated.
Old Jun 1, 2017 | 06:39 PM
s carter's Avatar
s carter
A common failure on the O-D Switch is the wires if not Carefully Tie wrapped to Shiftier Stalk the wires can brake from Switch i have Soldered many on in the past. or here is a Source of a Replacement
https://corvetteparts.com/item/switc...sion-1986-1988
or if you wish you could remove the switch and possibly get at a Radio Shack type of store and bring the Harness over
