Intermittent Strange Noises 92 LT1
Old Jun 4, 2017 | 09:36 AM
Cool Runnings's Avatar
Cool Runnings
Default Intermittent Strange Noises 92 LT1
Every once in awhile when starting up and turning at low speed, I will hear a 'grinding' sound like the passenger side rear brake has gone amuck. This noise is intermittent and that is what puzzles me. No 'grinding' sound when coming to a stop sign. Also, sometimes when I go from park to reverse I hear a 'clunk' like a U joint is going out (car is an auto). Car drives fine with no 'wobble' down the road one would expect with a bad U joint? Then again sometimes I hear a 'sharp cracking' noise upon first startup after going from park, reverse to drive?
I've looked under the car and everything seems fine? I don't have the facilities to do a proper inspection and have decided to bring her into the shop. The manager was a Corvette guy who owned both a C4 and then a C5. The car only has 52,000 miles on her and I'm certain it was never driven hard in it's 25 year life span. Just a old guys touring vehicle........
Any off the cuff ideas on what could be going on?
Old Jun 4, 2017 | 10:15 PM
A Peter C4's Avatar
A Peter C4
There are 6 u-joints only takes one to be a problem and not create a wobble,next could be rear wheel bearing, or maybe a differential problem. You need to get the car on a lift to diagnose.
Old Jun 5, 2017 | 08:51 AM
Cool Runnings
Thanks, going on lift tomorrow, thinking it's a U joint.
Old Jun 5, 2017 | 09:48 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
That is the way to bet.
To Intermittent Strange Noises 92 LT1
