dashboard electrical issue
Old Jun 8, 2017 | 11:38 PM
Judith Pelton's Avatar
Judith Pelton
1st Gear
Default dashboard electrical issue
Hi all Im just a new vette owner.Looking for any advice about this issue im having.I have an 86 vette that has the hazard lights come on and the dash lights go dark than light and than goes back to normal.Has only done it 3 times on me.Not sure if it's wiring or alternator or what.It only lasts for a few seconds when it does happen.Any help would be appreciated.Thanks in advance😊
Old Jun 9, 2017 | 12:49 AM
Cliff Harris's Avatar
Cliff Harris
Those symptoms can be caused by a bad ground at G201 (on the door hinge pillar, hidden by the sill cover and carpet). It can also be caused by a crystallized solder connection on the connectors that connect the two dashboard PC boards together. It is the pins on the ends of the connectors that causes the problems. You can tell by the overheated areas on the PC board (black spots).
