Rear window defroster doesn't work
Old Sep 30, 2002 | 01:32 PM
Danno355's Avatar
Danno355
Default Rear window defroster doesn't work
Hi Folks,
I check all my fuses, and they are fine, but my rear window defroster doesn't work.
I remember reading somewhere that film tinting prevents them from working, and if that's the case, poop, but I'll live. If its something i can fix, I'd like to try.
Any ideas?
Thanks in advance.
Old Sep 30, 2002 | 01:38 PM
JonM's Avatar
JonM
Default Re: Rear window defroster doesn't work (Danno355)
The tint has nothing to do with weather or not the grid works. Are you getting Voltage at the wire at the top of the strut? How about at the bottom of the strut? Are you getting continuity throughout the grid?
Old Sep 30, 2002 | 03:56 PM
SunCr's Avatar
SunCr
On mine it was because the power wire(s) had opened at the grid. Checks where it connects. Mine was broken right at the solder.
Old Sep 30, 2002 | 06:52 PM
1MoorTym's Avatar
1MoorTym
Mine was busted right at the connector from being flexed every time the hatch opened/closed.
Old Oct 2, 2002 | 12:32 AM
Wilson6t7's Avatar
Wilson6t7
Try unplugging your connectors and cleaning the connections. Thats all I had to do to get it working again.
Old Oct 2, 2002 | 02:26 PM
Danno355's Avatar
Danno355
Thanks everyone. I'll hopefully be able to check when I get home. Been pulling some long days so far this week.
I'll check everything, and do measurements of voltages if it isn't apparent in the connectors.
:cheers:
To Rear window defroster doesn't work
