One last idle adjustment???
Old Mar 19, 2018 | 10:40 PM
KB in CO's Avatar
KB in CO
Originally Posted by Tom400CFI
I would be checking the Coolant temp sensor, based on that last post.
Well, it took me a while, obviously, to change out the coolant temp sensor, put in a brand new one but no change. Super hard to start when cold, runs rough up to about 180 degrees then runs great after that. Any ideas what I should check next?
Cold start injector I'm guessing is next.
Old Mar 20, 2018 | 12:23 AM
xrav22's Avatar
xrav22
Before you change it clean the connector, I feel I have to know the answer to this too.
It cant be too hard to figure out. I would make sure the throttle body is open a hair.
You set TPI to .54 v . Wow this is a brain teaser.
Good Luck.
