[Schrader Valve]: Need one!
Old Sep 30, 2002 | 08:49 PM
scorp508's Avatar
scorp508
Default [Schrader Valve]: Need one!
Anybody know where you can buy the inner core of the schrader valve on the fuel rail? It seems that I have lost mine. :boxing Thanks!:)
Old Sep 30, 2002 | 08:52 PM
VQT88Vette's Avatar
VQT88Vette
Default Re: [Schrader Valve]: Need one! (scorp508)
Would the inner core of a tire valve works?
Old Sep 30, 2002 | 09:01 PM
DON M's Avatar
DON M
The seal on a tire core may not be compatible with fuel or its additives. Any A/C shop or supply house has them and they are designed with higher pressure and chemical resistant seals, to work with refrigerants.
Old Sep 30, 2002 | 09:10 PM
Nathan Plemons's Avatar
Nathan Plemons
The core from a tire stem will work. I can't say how long it will work, but it worked for a month or so while I had my fuel pressure gauge off.
Old Sep 30, 2002 | 09:17 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: NAPA has Schrader valves and they are inexpensive
Jack
Old Sep 30, 2002 | 09:18 PM
65Z01's Avatar
65Z01
Yep, just pull the core out of your spare.
Old Sep 30, 2002 | 11:56 PM
VetteNoob's Avatar
VetteNoob
I have one new one left over from when I retro-fitted my A/C. I have 2 used ones that are still in good shape. Shoot me an email if you need it. I bought the shrader valve kit from NAPA for like $4.
Old Oct 1, 2002 | 12:06 AM
baddmann's Avatar
baddmann
Default Re: [Schrader Valve]: Need one! (jackdaroofer)
Jack
Old Oct 1, 2002 | 12:23 AM
Bluevette85's Avatar
Bluevette85
Autozone has one for the A/C that should work.
Old Oct 1, 2002 | 03:26 AM
Ron78Z&66Vette's Avatar
Ron78Z&66Vette
Default Re: [Schrader Valve]: Need one! (65Z01)
I've been using a tire calve core for more than a year no. I pulled the cap off the fuel rail to check my fuel pressure and I had no leaking at all.
Old Oct 1, 2002 | 05:27 PM
tdock's Avatar
tdock
Default Re: [Schrader Valve]: Need one! (Ron78Z&85Vette)
I have one, just wanted to have the cap for the fuel rail, shoot me an email if you need it.
Old Oct 1, 2002 | 05:32 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: [Schrader Valve]: Need one! (tdock)
$4 from Napa you say..what's the part # or something? I have a schrader valve...COMPLETELY gutted for a Nitrous Solenoid connection. I need a regular one. Thanks for the tip guys!
Old Oct 1, 2002 | 05:43 PM
vader86's Avatar
vader86
hmmm, lemme think what else Schrader Valves can be used for......
Old Oct 1, 2002 | 11:06 PM
scorp508's Avatar
scorp508
I lost my core and want to plug it up so taht I can use a normal non-electric fuel pressure gauge saturday.
Old Oct 1, 2002 | 11:35 PM
tommelton's Avatar
tommelton
Default Re: (scorp508)
Scorp,
How do you have your inside electric fuel pressure gauge connected to the fuel rail? Pics please...
Thanks..
-Tom
Old Oct 1, 2002 | 11:47 PM
scorp508's Avatar
scorp508
I took the core out (which I can't find the bag I put it in) and installed a couple of fittings and the pressure sending unit. This is what it looked like back when I redid the top end.
(edit: It appears my webserver is down right now.)
It has a single black wire running back to the gauge in the a-pillar pod.
[Modified by scorp508, 10:48 PM 10/1/2002]
To [Schrader Valve]: Need one!
