Ok, time to ask about Cam and Headers guys. pls help
I have done A LOT to my Vette in the past few months, since I bought it. It is now time to talk Cam and Headers. I have an 86 Cast Iron Heads w/126k miles. It is an Auto and I live in California. Some of my Q's are: Are headers legal in cali, pass SMOG? shorty headers? which are better long-tube, shorty? Do I need to change out my CHIP if I do the headers and/or Cam. what does somthing like this cost if I have it done professionally? I have asked around town and no one will touch it, most don't even think it is legal. I looked in Elckers and MAD, they don't have headers for 86 Vette. not cali legal anyways.
Cruise-In II Veteran
Re: Ok, time to ask about Cam and Headers guys. pls help (dbwade36)
There are no CARB legal headers with an EO number. You might approach your local CARB rep and see what is required to get a personal exemption.
Or you can just port the stock headers and install a 2 1/2" manderl bent front Y (have the pre-cat shells welded onto to the pipe for the visual inspection).
For some cams I'm sending you some L98 test data.
Received 1,401 Likes
There arent any LT headers with a CARB number. Shorty's are pretty much worthless too.
You wont have to change the chip for headers, but you will if you change the cam. The Cam you pick depends all on the HP you want and whether or not you have emissions, and also whether you want to keep the TPI setup or go Superram/Miniram (i know SR has a CARB, dont remember if the MR does).
You dont have a roller cam either, so that also plays a part in selection.
