Fuel Tank Pressure?
Old Jun 21, 2017 | 11:53 AM
Kdeman1's Avatar
Kdeman1
Default Fuel Tank Pressure?
Hello,
Ever since ive had my 87 my fuel tank hasn't been "breathing" properly. The tank builds up pressure and then when I remove the gas cap it blows out for awhile. Does anyone have any ideas where I can look for a possible clog or has fixed this before?
Thank you!
Old Jun 21, 2017 | 12:05 PM
JimLentz's Avatar
JimLentz
My '92 does something similar, but has never seemed to be an issue.
Old Jun 21, 2017 | 01:02 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Normal ops
Old Jun 21, 2017 | 02:21 PM
hockeyhead019's Avatar
hockeyhead019
My 92 does this as well. Figured it was normal, hopefully bill is right
Old Jun 21, 2017 | 02:42 PM
jsmcol's Avatar
jsmcol
I think they all do it right, it is a pressurized system, that's why when you change the fuel filter you have to depressurize or you end up with the contents of your fuel tank all over you!
Old Jun 21, 2017 | 05:39 PM
vader86's Avatar
vader86
It should do that when the engine is hot, not when cold. Fuel is circulating back and forth from the engine and some gets returned to the tank, this fuel is now heated and expands, building pressure in the tank. Federal emissions requires the system to be closed and under pressure, instead of dumping fumes into the atmosphere all the time.
To Fuel Tank Pressure?
