MSD 6 Install??
Old Oct 1, 2002 | 04:44 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default MSD 6 Install??
Where is the best place to put this msd system...????
Where to mount????
Problem....saw some on the forum, but now I can't find...HELP....
THANKS
tony :confused:
Old Oct 1, 2002 | 08:48 AM
trupp's Avatar
trupp
Default Re: MSD 6 Install?? (oldace84)
I mounted mine on top of the battery with high strength velcro. Installation there gave me relatively short wire harness lengths, which I saw as a plus. Others have mounted them in front of the tires on either side of car with much success, either way any of these three locations will work.
Old Oct 1, 2002 | 09:19 AM
vader86's Avatar
vader86
lots of people mount it underneath one of the headlights
Old Oct 1, 2002 | 12:40 PM
85Procharged383's Avatar
85Procharged383
Default I put mine .....
I put mine on the passenger side. Laying on top of the Black AC box thing... up close to the firewall, but on the "outside" edge of it....at an angle. No clearance issue's and away from heat. I wish I had a pic...but I don't. Also, to keep from cutting wires...they do make a "plug and play" harness that makes things alot neater...and will allow you to go back. I highly recommend it.
To MSD 6 Install??
