Corvette wheels
Oct 1, 2002 | 02:12 PM
Corvette wheels
I am working on a reference page with all the 1984-1996 Corvette wheels.
I have tried to find good pictures of each desing.
I want to use picutures of Corvettes in stock condition.
I think the 88 16" wheel is the least known one.
I fist saw it at a meet, and I did not think that it was a stock wheel at first.
Please post if you have additional information that I should add.
http://w1.601.telia.com/~u60113743/corvette_wheels/
Oct 1, 2002 | 02:22 PM
Re: Corvette wheels (JoBy)
You should add the offset of the 84-87 wheels as 38mm, and the 88-96 offset is 56mm
St. Jude Donor '05-'06
What about the 88 Callaway wheels ?
Oct 1, 2002 | 02:31 PM
Re: Corvette wheels (vader86)
Thanks, I will do that.
What is the rear offset for zr1?
Are any other different?
[Modified by JoBy, 7:37 PM 10/1/2002]
Oct 1, 2002 | 02:37 PM
1993 ZO7 Front 9.5" 275/40-17 Rear 9.5" 275/40-17
I think the rear offset mightve been different for Zr1s, why dont you ask in the Zr1 section
Oct 1, 2002 | 02:40 PM
Re: Corvette wheels (HTRK-1)
Same design as 1993 base?
[Modified by JoBy, 7:40 PM 10/1/2002]
[Modified by JoBy, 7:43 PM 10/1/2002]
Oct 1, 2002 | 02:48 PM
Re: Corvette wheels (Coupe89)
Should I add Callaway too, or keep it stock GM?
Did Callaway change wheels on all years?
Might add those at the end in that case.
Oct 1, 2002 | 02:50 PM
I "think" the ZR1 rear offset was 36mm. Ask the ZR1'ers to be sure though.
Oct 1, 2002 | 02:55 PM
Oct 1, 2002 | 02:56 PM
Re: Corvette wheels (Silver89)
Thanks!
Oct 1, 2002 | 03:32 PM
Oct 1, 2002 | 03:51 PM
Oct 1, 2002 | 03:54 PM
Re: (Coupe89)
Oct 1, 2002 | 04:11 PM
Re: (Coupe89)
Quote:
Callaway has its own RPO number: B2K.
Factory option.
What years other than the 88?
tires?
Oct 1, 2002 | 04:21 PM
Does the 1996 Z51 wheels look like base or like the Collectors Edition?
Oct 1, 2002 | 04:29 PM
Re: (JoBy)
Callaway had thoses rim from 88-89.
Z51 in 1996 were 9.5" all around
The collectors were 8.5" and 9.5" if they didn't opt of the Z51.
Oct 1, 2002 | 04:34 PM
Re: (Coupe89)
Did the non CE Z51 have sawblades or 5-spokes?
Oct 1, 2002 | 04:37 PM
Re: (JoBy)
Standard was sawblades.
Oct 1, 2002 | 06:02 PM
One thing I noticed, you have the 91 and 92 style listed for base models up to 96. But, in 93 the wheel changed it basically looks the same but with a machined face.
[Modified by vette92_1, 4:34 PM 10/1/2002]
