im lost
Old Jul 1, 2017 | 08:14 AM
Tim410's Avatar
Tim410
1st Gear
Default im lost
Low oil pressure light keeps flashing on when i accelerate quickly and car studders but never turned off. Put on the machine and no codes are popping up. So far i changed the fuel filter, oil lever sensor and oil pressure sensor. I was told it could b the intake manifold gasket... Any advice guys???
Old Jul 1, 2017 | 08:31 AM
ex-x-fire's Avatar
ex-x-fire
Put a mechanical oil pressure test gauge on it & drive it.
Old Jul 1, 2017 | 09:44 AM
s carter's Avatar
s carter
Use a pressure Gauge, also what year is the car. Remember some cars have a switch for the Fuel pump and Sensor for the Dash Reading.
Seen if it truly does drop if so I would give Oil Pump and pick up a Look at.
To im lost
