Removing headlight plunger from switch
Old Jul 2, 2017 | 09:06 AM
garyc4's Avatar
garyc4
Default Removing headlight plunger from switch
As well-worn as this topic may seem, I cannot find specific instructions. I have an 84, the dash pad is already off, exposing the top of the headlight switch. The **** and plunger/shaft/stalk sticking out of the dashboard needs to be replaced, as it is broken near the end and will not retain the **** any longer.
I have a replacement new ****/plunger. I have read there is a button of sorts that when depressed, will release the plunger, allowing m to pull it out and replace with the new one.
I cannot find this button.
Any help on exactly where this is, how hidden it is, what tool is needed to get to button, and if it is accessed from the top, side or bottom, would be greatly appreciated.
Have searched other threads, and cant find this info. Thanks!
Old Jul 2, 2017 | 09:16 AM
belairbrian's Avatar
belairbrian
Look at post 12. You can see the plunger under the switch.
https://www.corvetteforum.com/forums...on-86-l98.html
another view without the pesky car in the way
Old Jul 2, 2017 | 09:28 AM
WVZR-1's Avatar
WVZR-1
Pull the rod to the detent then push the button and finish the removal. I seem to recall that if you push the button and then pull from the OFF position it hangs. I've not done an early GM HL switch for many years but that's best of my recollection. The switch was used by all GM for decades.
Old Jul 2, 2017 | 09:53 PM
belairbrian
yep, my 54 belair has the same setup.
Old Jul 4, 2017 | 10:14 PM
garyc4's Avatar
garyc4
Thanks to all. Got the stalk out, and will replace as soon as I put the cluster back in after replacing the bulbs. Appreciate the responses.
To Removing headlight plunger from switch
