ignition problems
Old Jul 2, 2017 | 06:40 PM
templao2000's Avatar
templao2000
1st Gear
Default ignition problems
hi, i have fast ez efi 2.0 on my 350 l98 chevy, can`t start, cranking moment send jumping rpm, example 200-800-5000-600-4000rpm, its normal? and no have point output signal
Old Jul 5, 2017 | 07:16 PM
azanardifan's Avatar
azanardifan
Are you using the Dual Sync distributor and ignition box to allow the computer to control your timing? I used that set up on an 86 and didn't have any issues with timing. I know you have to be careful on having a good connection and shield the computer away from high voltage. I put my computer in the area on drivers side under the headlight and the MSD box on the passenger side under the headlight. I created a bracket for the coil on the passenger side right next to the hood latch.
