TH700R4 help
Old 07-04-2017, 09:45 AM
JoBy
JoBy's Avatar
To automatically activate TCC on fourth gear without computer. Connect blue wire to tan wire on the trasmission connector.
It will not fix your other problems.
arbee
arbee's Avatar
Originally Posted by Jdog91
If I could post a video I would . All gears are lost when warmed up almost like it's in neutral. Very strange. Could old fluid be the cause. Should I flush the liquid I know it's a pita to drop the pan.
When you say "all gears" are you saying reverse also? And no, old fluid will not cause this.
Old 07-04-2017, 10:10 AM
confab
confab's Avatar
This ^
Old 07-04-2017, 10:16 AM
confab
confab's Avatar
Let me guess.. It's not all the gears, right?
It rolls out fine, shifts to third and it is like you are in neutral then?
Old 07-04-2017, 10:43 AM
Jdog91
Jdog91's Avatar
Yes all gears 123 r d all of them. Like there is no pressure to stay in gear. That's why I thought it was a clogged filter. Do these usually go bad after sitting for a long time.
Old 07-04-2017, 10:44 AM
Jdog91
Jdog91's Avatar
I can feel the transmission shift through all the gears
Old 07-04-2017, 10:56 AM
confab
confab's Avatar
Well, line pressure is the pressure that holds your clutches on and keeps the trans from burning up by slipping and destroying them.
The TV cable raises this pressure when you step on the gas to prevent that.
Are we SURE this thing is attached and adjusted correctly?
There's some posts on the other page that are pretty specific.
One thing is for sure, if you mess it up, you will burn the trans.. So it is important to take your time and make sure it's totally, completely, 100% right before proceeding.
Old 07-04-2017, 11:01 AM
Jdog91
Jdog91's Avatar
Is trans still fine all I did was lightly drive up and down my driveway. At wot the cable is pulled all the way. maybe needs to be tighter but it definitely is pulling on it.
Old 07-04-2017, 11:10 AM
confab
confab's Avatar
Well, it needs to be maximum tension at WOT..
Also, and I touched on this and so did Arbee.. The rate of rise has to be correct.
Meaning, basically, that where the cable mounts to the carb? That distance from the cable pivot to the center of the butterfly shaft needs to match your old setup. Otherwise, you can pull the cable all the way taught, but the rate is too low because the arc the pivot travels is less.
I assure you, this is a big, big deal. I personally burnt a performance transmission out of a TPI 57 Chevy because the owner modified the aftermarket throttle linkage in exactly this way, and I didn't catch it.
It happened very, very quickly.. So, you need to verify this step 1000% before proceeding, or it can destroy your trans.
My 2 cents. Good Luck!
Old 07-04-2017, 12:35 PM
Jdog91
Jdog91's Avatar
It is bad for it to be pulled too tight. Couldn't find anywhere the measurement of slack at idle
Old 07-04-2017, 12:42 PM
arbee
arbee's Avatar
Have you or have you not installed a carb linkage that is SPECIFICALLY designed for 4l60 use on your model of carb??
Old 07-04-2017, 12:44 PM
confab
confab's Avatar
No.. It's how it is supposed to work. Full tension at WOT. Not hard on it at all. Don't worry about it.
There is no slack adjustment.
However and again, it has to be pulled at the right rate.. Like, imagine the solar system and everything rotating around the sun.. Look at the small arc the closer planets travel compared to the ones further away?
So, it's important to get the cable mounting right. This thing does the job the vacuum modulator used to do, and it has to be RIGHT.
Old 07-04-2017, 12:45 PM
  #33
Jdog91
Jdog91's Avatar
No I used the old mount but it seems to work.
Old 07-04-2017, 12:48 PM
  #34
Jdog91
Jdog91's Avatar
  #35
confab
confab's Avatar
No, we're talking about where the cable end attaches to the carb and pivots.
Old 07-04-2017, 12:52 PM
  #36
confab
confab's Avatar
Old 07-04-2017, 12:56 PM
  #37
arbee
arbee's Avatar
OK, I will try this one more time. Pulling on the TV cable is one thing, but at the right RATE is another. Both Confab and myself have tried to explain to you the importance of RATE of pull as the throttle is advanced. Unless you buy an aftermarket bracket DESIGNED for your carb, you will not get this proper RATE. Goodbye trans!!
To TH700R4 help
Old 07-04-2017, 01:00 PM
  #38
Jdog91
Jdog91's Avatar
Now I understand I'm sure there is a way I can make it work without aftermarket bracket to work temporarily. Removed the trans filter and there was grey mud like material in there.
Old 07-04-2017, 01:01 PM
  #39
confab
confab's Avatar
This ^^^
What you will often find is that lower connection is for a kickdown, and isn't long enough to run the TV properly.
THAT was what my buddy did with the 57 I smoked. He had the linkage set up for a kickdown from his previous trans, and when I put a 4L60 in it, it burned up on the test drive..
Old 07-04-2017, 01:02 PM
  #40
confab
confab's Avatar
Some of that is normal. Transmissions don't run as clean as engines do.
Various reasons, but it is a matter of degree.
Quick Reply: TH700R4 help
