Moderate frame rust under my battery :(
Old Oct 1, 2002 | 10:01 PM
needanother1's Avatar
needanother1
Default Moderate frame rust under my battery :(
How bad a thing is this, and what should I do about it? Looks like the battery has leaked at some point and instead of the acid running down the "drain" in the battery tray, some ended up on the frame. Car's an '88.
I would imagine that this has to be a fairly common thing. I'm planning on cleaning the area off as much as possible and applying some type of rust-stopper. How concerned should I be about the damage?
Jason
[Modified by needanother1, 2:03 AM 10/2/2002]
Old Oct 1, 2002 | 10:40 PM
MagRed_04's Avatar
MagRed_04
Default Re: Moderate frame rust under my battery :( (needanother1)
Same thing happened here.... Sanded it down and painted over it with black rustoleum paint... Good as new!
Old Oct 1, 2002 | 11:02 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Depends on the extent of damage; minor should be good to paint over after a thorough cleaning.
You might also want to clean the area around those two relays above and behind the battery. Mine showed some white residue, no doubt from fumes.
To Moderate frame rust under my battery :(
