well... this blows
Old Oct 2, 2002 | 08:09 AM
fathermojo's Avatar
fathermojo
Default well... this blows
got the cooling probs straightened out yesterday, now the brakes take a nose dive....I'm really really hoping that the calipers have have bottomed out on travel as the pads are pretty much down to the backing plates. I pulled the resevoir cap and found that the bladder was inside out... No leakages though either around or behind the booster....taking ideas
AAAAARRRRRRGHH! :U
Old Oct 2, 2002 | 08:30 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: well... this blows (fathermojo)
What's the brake problem symptom?
Old Oct 2, 2002 | 01:15 PM
fathermojo's Avatar
fathermojo
Default Re: well... this blows (65Z01)
pedal goes to the floor.. after sitting, i get some pressure back but repeated pumping sends it back to the floor again.. but.. oddly enough.. not getting a brake light warning... probably needs a nose bleed
Old Oct 2, 2002 | 01:22 PM
vettmech's Avatar
vettmech
It sounds like it's time for a routine brake job :seeya
Old Oct 2, 2002 | 01:23 PM
vader86's Avatar
vader86
sounds like the Master Cylinder
Old Oct 2, 2002 | 07:11 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Sounds like all of the above.
Old Oct 2, 2002 | 10:37 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Time to get to work......Lot's in front of you......but after you'll be happier....Do the work yourself.......better than someone else, although sometimes not cheaper...
tony :smash:
[Modified by oldace84, 9:38 PM 10/2/2002]
Old Oct 4, 2002 | 07:21 AM
fathermojo's Avatar
fathermojo
Default Re: well... this blows (oldace84)
0kay.. got it.. primary piston in the master cylinder plunged and froze up... replacing the master cylinder cylinder today and doing a complete douche on the system... going ahead and replacing the pads while i'm at it since I have to take the wheels off anyway to bleed the rear out.
musta sat for too long so i can't blame this one on bubba :U
Old Oct 5, 2002 | 07:54 AM
fathermojo's Avatar
fathermojo
replaced the master cylinder, replaced the pads, douched the entire system and things are looking up.. but.. i would've liked to replace the resevoirs while i was at it but can't seem to find one....master cylinder was a reman so i didn't get a new resevoir or low fluid sensor...anybody know who sells those two items?
thanks
To well... this blows
