NAPA Optispark distributor verdict
My original opti died @~155k, 5 years ago. At the time, I lived in the middle of no-f'ing-where, Colorado (Telluride) and I needed a distributor ASAP so I bought the only thing that was available; a replacement from NAPA. It was ~$500, so as much as any of the "premium" units (I use quotes b/c we know that "premium" units have no better statistics than el-cheapo units -they just cost more). I had low expectations for longevity but it got the car running in the short term.
5 years and ~30,000 miles later, it's starting to fail. The other day while driving, engine "shut off" and simultaneously, the tach went to 0. I coasted to the side of the road, tried to start it, no start. Got out and jiggled the opti harness and it fired right up, ran fine (the wire jiggling turned out to be coincidence). That night I put my scan tool in the car so I could watch low res and high res signals if/when it acted up again. Over the next few days, it "hiccuped" a few times but events were so quick I couldn't see anything except the tach needle "jerking". I knew it was the opti, but wanted to prove it. Yesterday, I was driving home from work and she shut down on me again. Tach fell to 0, and I grabbed the scan tool and looked at it as the car coasted in gear, engine spinning, not firing and tach reading zero. On the scan tool, high res read "0", Low res read "0". Before I came to a stop, car came back to life both signals came to life too and I finished my commute.
Bottom line: 5 years from a non-vented NAPA unit. Not bad....but when you factor in the price, it's not good. I wouldn't buy another one. I'll try a Sac City one next.
you can find them in junkyards and every once in awhile can find them on ebay (if you know what questions to ask)
I don't mind changing the thing...so I'd rather be CHEAP and change it (if necessary). Obviously this decision is different for others.
I am just curious as it seems the Mitsubishi OEM modules don't fail. But they are also no longer available.
Sure thing. I agree with you; I also doubt that it's a Mitsu unit. I'll let you know.
or maybe not; that little piece of the wiring harness you "jiggled" is about two feet long, easily accessible from both ends, and where it plugs into the opti is a direct vertical connection and with the help of gravity, anything that can work it's way past the what, 180,000 mile old "weathertite" connection, can and will work its way in and cause corrosion and electrical problems.
So it was coincidence.I can confirm that two ways; 1. I removed that harness segment, visually checked the pins/connector...it was good, clean, nothing bent. I checked both ends. 2. When it starts a couple minutes after dying, I can then jiggle all those same pieces of wire/harness until the cows come home and it won't miss a beat.
I'm pretty positive it's not the wiring.
He did not say what he cleaned them with though.
All he has available are Opti design 1's. I was looking for a spare for my '96 to swap out the original and put it up on a shelf.
I might try that w/this one...depending on how it looks when I get it apart. I say "might" just because the nature of my random failures (then starts and drives fine two minutes later) seems more "electrical" failure to me than contamination failure.
Tom, There is a guy on eBay that puts NOS Mitsu sensors in MSD housings. Might be worth a look.
Maybe I should buy and change just the sensor...
MITSU Sensor
MITSU Sensor
I'm with Tom: the opti replacement job isn't as hard as the webernets folklore make it out to be, so if you can get away with doing it every five years that's worth saving money on the unit. But on older one I would look into converting to a vented cap. Go through and put RTV on the cap and plate seals, and maybe some silicone grease on the harness plug pass-through, and Loctite Blue the screws for the rotor. The sensor would probably last forever after that. Too bad the bearings aren't replaceable.
MITSU Sensor
Ya know I like what the mfr of the Sac City Opti says about thier Opti sensor. To be fair I won't post the mfr name. But for thier pricing I would be compelled to give them a try next time I need an opti. They sell both thier "improved" Opti and a brand new AC Delco unit ($400) - don't know how they are marketing the AC Delco unit with a Mitsubishi sensor unless it truly has one. But they advertise thier Mitsubishi sensor as improved over the OEM unit (which they sell in a whole ACDelco Opti).
Only first hand experience can help here.
