smells like gas
Old Oct 2, 2002 | 12:11 PM
dtorc4's Avatar
dtorc4
Default smells like gas
This is a recent development... when I'm cruising along straight, everything is fine. However, when I make a fast turn or change lanes at highway speeds, I smell gasoline. Could there be a crack in my gas tank? WTF? :confused:
Old Oct 2, 2002 | 01:04 PM
vettmech's Avatar
vettmech
Default Re: smells like gas (dtorc4)
does the symptom change with the amount of fuel in the tank?....... It could be a cap that doesn't seal but yes it could be a leaky tank.......... any other conditions? :seeya
Old Oct 2, 2002 | 04:13 PM
dtorc4's Avatar
dtorc4
Default Re: smells like gas (vettmech)
It doesn't seem to change with the amount of gas in tank. I will purchase a new cap though, just to make sure. However, if it is just a bad cap, would I be able to smell it in the car like I do? :cheers:
Old Oct 2, 2002 | 04:22 PM
vettmech's Avatar
vettmech
OK good point........ I'd check it out then by removing that boot around the cap then and making sure everything's tight there. Also make sure the bolts are tight around the pump unit and that the gasket there isn't leaking........ at this point you may be able to see something...... do you have your spare tire holder in place ?..........if not you may be able to see a lot of the tank from UNDER the car :seeya
Old Oct 3, 2002 | 04:43 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Check evaporator system........are all lines hooked up...any thing else when you look at it????
FYI
tony :smash:
Old Oct 3, 2002 | 05:11 AM
dtorc4's Avatar
dtorc4
Which components and locations would I need to check for the evaporator system - I'm not familiar with it.
Old Oct 3, 2002 | 12:29 PM
tdock's Avatar
tdock
Evap System:
There's a charcoal canister back under the passenger side rear quarter panel, kind of near the muffler. There is a third hose coming out of the gas tank that vents into the canister when pressure builds up in the tank and a vacuum line to pull the fumes back into the intake/throttle body. 96 has a panel that pops off but I think to really get at it you might want to remove the wheel and wheel well.
[Modified by tdock, 10:31 AM 10/3/2002]
To smells like gas
