Power steering rack removal HELP
Old Jul 16, 2017 | 07:36 PM
BrainDrainin's Avatar
BrainDrainin
Default Power steering rack removal HELP
I decided to replace the whole rack instead of just the inner tie rods on my 93. I have a arms and sway bar out for a full rebuild. I am having a ton of trouble getting the power steering lines off the rack... I don't see any way to get a wrench on them???? the other issue is I can not pry the rack totally out of the steering shaft joint. I saw super Chevy while write up on this job but it looks like they have much more room, and it was on a earlier c4. Anyone have tips or tricks to get this sucker out??
Old Jul 16, 2017 | 08:41 PM
BrainDrainin
Wondering if I have to remove ac and go from the top, also read some people remove radiator, but I don't see the benefit of that
Old Jul 17, 2017 | 01:59 PM
dizwiz24's Avatar
dizwiz24
my radiator was out and a/c was removed when i removed mine. put a polyurethane bushing in it Also while i was at it.
Old Jul 17, 2017 | 04:33 PM
grandspt's Avatar
grandspt
I did this a while ago, I had the radiator in it but water pump and optispark was removed. It was still a b**ch to remove the rack.
Sorry, I have no tricks for you that would make it easy. But make sure you have some good flair wrenches.
Old Jul 17, 2017 | 07:14 PM
cmontel727's Avatar
cmontel727
The only help I can offer is to use a crowfoot socket on the lines. That was the only way I could get enough torque to loosen them.
Old Jul 18, 2017 | 02:11 AM
Cliff Harris's Avatar
Cliff Harris
I couldn't get a flare nut wrench to move when it was on the flare nuts on the rack because of interference with the frame and hydraulic lines. I was replacing one line because it was leaking, so I bent it back and forth until it broke off (didn't want to hacksaw it because of metal particles).
When I first started to take my rack out I thought I could get it out without removing the anti-roll bar. I was wrong about that.
Old Jul 18, 2017 | 05:27 PM
BrainDrainin
Thanks for the replies fellas, I'm going to give it another stab tonight, ok move the ac compressor out of the way and if still no room... the radiator. I guess I'll keep digging and taken things in the way out. I will report back tonight, thanks again
Old Jul 31, 2017 | 08:54 PM
ajd3rd's Avatar
ajd3rd
Any update on removing the lines. I have a 94 I need to do shortly.
Old Sep 15, 2017 | 06:45 AM
BrainDrainin
to get the front bigger line you slide the wrench from under the boot, top one I cut the line because it was seized. Advance sell a 90• hardline I used for replacement 16m I believe
To Power steering rack removal HELP
