ZF Clutch kit question
Old Oct 2, 2002 | 11:18 PM
lone73's Avatar
lone73
Default ZF Clutch kit question
Got the clutch kit from Carolina Clutch. I don't have a separate T/O bearing. Is it part of the pressure plate assembly? There is a bearing of sorts in the center of the pressure plate. Thought that might be the T/O bearing. Never been into it before, don't know what to expect.
dr
Old Oct 3, 2002 | 01:56 AM
MarkBychowski's Avatar
MarkBychowski
Default Re: ZF Clutch kit question (DavidR)
Some of the kits come with the T/O bearing already attached to the pressure plate. There's a C-shaped spring clip that holds the bearing to the center of the pressure plate spring. It's the only bearing on the assebly, so it sounds like yours came with it attached.
Old Oct 3, 2002 | 10:25 PM
lone73's Avatar
lone73
Default Re: ZF Clutch kit question (MarkBychowski)
Yup, it's got a spring clip holding the bearing on. It must've been preassembled.
Thanks Mark for setting my mind at ease ! I won't get to tear the thing apart for a few more days and now I know its complete and I don't have to figure it out thru Carolina Clutch.
Thanks!
dr
ps: your mod's sound pretty cool.
To ZF Clutch kit question
