Edelbrock Hi-flow too base weight
To be honest.. These days it seems people are bot really modifying and documenting these cars anymore.
I know the info is out there. Do a search or check stickies for the weights. I think Aardwolf had documented weight stuff like that.
Unless you are racing for points, I don't think it matters what it weighs. Maybe 18-20lbs?
https://www.corvetteforum.com/forums...-and-info.html
i want to shut down lsx based platforms.
every ounce matters
Received 3,043 Likes
St. Jude Donor '05
Try Edelbrock they gotta have that info somewhere unless somebody here has one they can weigh for you. Yours lost weight for sure edit: bet less than 2 lbs
Anxious to see your results it was awful stout before for a superram motor. You sure have put in the time and $
Thanks bud, the intake should be back this week. I have a few friends who will help me expedite install. Thread and results will be soon!
I would think a couple of handfuls of aluminum shavings would weigh very little because of the minimal weight of the material. If a manifold started out at 20lbs, the weight removed from porting would be in the ounces even though the volume may be large.
