Trouble finding Vehicle Speed Sensor
Old May 3, 2021 | 09:08 PM
MJ6's Avatar
MJ6
Originally Posted by WVZR-1
If it isn't the connector on your original and there are no other issues the '91+ and a correct connector should correct the VSS 'signal'.
I finally had time to examine the VSS plug and learned one of the wires has been chewed through, no doubt rat damage. The rat chewed the wire so close to the plug that fixing it is almost impossible. I was amazed how little space there is to work, it's terrible trying to remove the plug, finally used a long curved set of pliers to reach and remove it. I'm going to need a new plug and splice it into the existing wires, I tried to replace the old plug to keep dirt out, however, there is no way I can get this thing back in place, it just won't insert back in, I tried for hours without any success. Can't figure why it will not go back in, there is no damage to the plug so it should slide right in. This whole repair is a nightmare no room to work and lying on ones back is no fun. Have any ideas?
